  • Replies 129
Posted Images
yeah pretty much on the money there stevie.
As Ruby said earlier the 1st mistake was to lie to the guy. Cop can look in your car in a public place without a warrant if you give him reason to believe you're carrying contraband or a weapon or if you appear to be hiding something (hence the lie)
yeah fair enough i shuoldnt have lied but the main reason he pulled me over was coz of the exhaust being 2 loud so no matter what i was gonna definetly going 2 get a defect, how long is the wait 2 get in2 regency these days??? coz i go overseas for a month in november so i wanna get it sorted before then if it aint gonna cost me shitloads.........
guess im riding my pushbike 2 work 2morrow, thank god its fully carbon fibre and super light n quick
Edited by ovrtym33
https://www.sau.com.au/forums/topic/234094-defected/page/3/#findComment-4103144
Dan, if your not competent enough, send it to michael or i can return it to stock at my place if need be. Up to you mate. Will look after you either way.
yeah thanks Ryan that'll be awesome i want 2 get it sorted asap, i found most of the spare parts today, hopefully i got them all, 1st thing i gottr do is see Michael bout the exhaust then or has anyone got a stock 1 i can borrow 4 quite a while???
Steve, yeah its FULLY SIK MATE :P
Luke, thanks 4 the offer but i need 2 be rolling on stokies until ive passed regency, so its up 2 u mate
https://www.sau.com.au/forums/topic/234094-defected/page/3/#findComment-4103185
dan might be a wise decision to get my laptop onto your power fc and save your tune mate, just incase...even tho it'll stay on there..just incase something happens.
yeah good idea Ryan, that was a bloody good tune u guys did, could feel the difference when i left satdee, boost came on quicker pity i didnt hav time 2 enjoy it :P
Luke the rim size is wat i also got done 4 so ill need 18" or smaller on all the time untill i pass, i got sum stokies at home ill just throw sum cheap retreads on them
https://www.sau.com.au/forums/topic/234094-defected/page/3/#findComment-4103207
Lock your glovebox and claim you lost the key for it!
A cop once accused me of lying when he said to me my boost gauge was a "rev tacho" and I said "That's a boost gauge" and he said "You better not be lying to me".
And to be honest, I got pulled over in my old 323 once which had a B6T engine conversion. The cop said "Do you have a blow-off valve under that bonnet?" and I said "No officer" and he said "Okay. Have a good night" and left... but I infact did have one :( but it's sprayed Black and under a heap of piping, so he wouldn't of found it.
If you can lie your way out of a defect, why not? Sure, it's being dishonest and all... but if it saves you a defect, then why not?
*waits for the flaming to begin*
https://www.sau.com.au/forums/topic/234094-defected/page/3/#findComment-4103666
Riiiiight. The ignition key locks and unlocks the glovebox Einstein. Didn't think that one thru.
Here comes the flaming ...
Good on you mate. Go set a good example for all Skyline drivers. :(
https://www.sau.com.au/forums/topic/234094-defected/page/3/#findComment-4103703
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
