  • Replies 129
Posted Images
booked into regency 19th sept $134
speaking to a compliance place today they said you prob wont get pass the first time so they'll give u a list of wat needs 2 be done before the next visit and thats all they will check and there is rarely a 3rd visit
thanks heaps Ron for the stock exhaust n airbox
https://www.sau.com.au/forums/topic/234094-defected/page/6/#findComment-4107719
Yeah they love repeat customers, atleast you have been warned, don't expect to have your car back on the road on the 19th... sad but true :P
how long did u have 2 wait 4 ya 2nd inspection luke??
wanna get it sorted and back 2 how i had it (minus rims n loud exhaust) before the car show in kadina so i can run it on the dyno there
https://www.sau.com.au/forums/topic/234094-defected/page/6/#findComment-4107845
man id be pissed of if my car had to go to regency as thatmeans id have to drive 660km but usually we get the poeple come up here and they will let you of with some things that arnt needed to be worried bout, good luck mate hope you strike it first go.
cheers... michael
https://www.sau.com.au/forums/topic/234094-defected/page/6/#findComment-4107879
I've been there on 3 different occasions and have past first time every time, its best to get a mechanic to have a full check over your car before you go, so anything wrong can be fixed before you go.
https://www.sau.com.au/forums/topic/234094-defected/page/6/#findComment-4108016
Dan,
dont forget we're here to help you return to stock...done it all before so it shouldn't take too long.
i appreciate that heaps thanks ryan
a mates mate had a similar highmount set up on his car had 2 change it back 2 stock recently 2 go thru regency gona hav him chek it out monday as most of his stock parts are still bolted 2gether so i might borrow his as my parts r in a million peices
ill be in 2 see michael satdee morn 2 get my current exhaust system made super quiet in preparation for my next set up
https://www.sau.com.au/forums/topic/234094-defected/page/6/#findComment-4108082
you're a rare breed Ryan and a champ :P
Thanks pete but anyone would help. Sorry to highjack thread but
I have to say Pete, I have utter most respect for the effort you are putting in to help Adrian, Damo and Everyone involved. Helps bring some faith back into society when people go out of their way and at their cost to help others out, especially to this extent. Thankyou.
no problem champ, sounds good. Michael has a knack for making super quiet exhausts on high powered cars. His own 280rwkw R31 is dead quiet on full song lol.
Edited by Ryanrb25
https://www.sau.com.au/forums/topic/234094-defected/page/6/#findComment-4108109
Hey, This sounds like a spliting image of me only 2 weeks ago, On south road at regency
park cop did a u turn at lights and pulled me over(in my lunch break at work), and went through the
whole car, got done for a bit.
Told me the same, that he was going to fine me for each infrigment(modification) totalling $3000, but
only issued the defect saying he was be kind.
He to boasted about all the skylines he defects, and in particular from this forum(named it)
Wouldn't be suprised if the twat is reading this now.
Good luck with regency :P
https://www.sau.com.au/forums/topic/234094-defected/page/6/#findComment-4108111
Heto boasted about all the skylines he defects, and in particular from this forum(named it)<
https://www.sau.com.au/forums/topic/234094-defected/page/6/#findComment-4108121
so long as i get the plenum back that's all! but it doesn't have the stock bov
thats cool man i still got the stock blowoff and pipe PM me ya num and ill try and pik it up this wkend mite n mite not need it but ill borrow it just incase
thanks mate
cheers 2 every1 for helping me and lending me parts n giving me great advice, i feel alot better now but still pissed off
hey ryan can u give me ya msn if u got 1 or add me [email protected]
https://www.sau.com.au/forums/topic/234094-defected/page/6/#findComment-4108145
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
