Item: need 2x bolts to hold the rear passenger seat in, 1x bolt to hold passenger seatbelt in
Condition:
Price:
To Fit: (What car) R33 Series 2 gts4
Contact: 0419848600 or reply to thread
Comments:need these asap
pic's :
hope this is the right section to post this in :rolleyes:
https://www.sau.com.au/forums/topic/234097-wtb-r33-bolts/
Dude they're 12mm bolts and the thread is 28mm long. Available at any hardware store.
cheers mate , wasnt sure as to what size n all they were
shall go to mitre 10 in the mornin and suss some bolts out
https://www.sau.com.au/forums/topic/234097-wtb-r33-bolts/#findComment-4103131
take the same bolt on the opposite side out from those spots and match them at a bolt shop expecially the seatbelt one. high tensile one is a must.
only problem is there isnt any holding the rear seats down , might just go to just jap wreckers and see what they have
https://www.sau.com.au/forums/topic/234097-wtb-r33-bolts/#findComment-4103845
Dude JET-25L, gave you the sizes; "12mm bolts and the thread is 28mm long".
Go to your local bolt place and ask for some high tensile 12mm bolts with a thread size of 28mm long. Its that simple, no messing around with second hand stuff.
https://www.sau.com.au/forums/topic/234097-wtb-r33-bolts/#findComment-4104307
i went to just jap dismantlers then mitre 10 ,
jap dismantlers are hopeless and have no clue about anything ,
mitre 10 i couldnt get anyone to help me and combined with being sick and dizzy i didnt feel like hanging around
gonna go to coventry later or tomorrow when im feeling better
//edit
my dad went to japco just now and they gave him the 3 bolts that i need
Edited by DamageInc
https://www.sau.com.au/forums/topic/234097-wtb-r33-bolts/#findComment-4104323
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
