The ecu is programmed to send fuel to ports on start up without need for touching throttle.
I would think if u need to do this id say ignition timing could be too retarded uumm what does your cars rev at when its cold?
Maybe sticky Idle air control sensor which is on the plenum sorry dont know how to check it tho!
https://www.sau.com.au/forums/topic/2341-cold-starts/#findComment-43184
Guest Boxhead
its not neccesarily cold starts that make myn not start.. its at my place.. wont start first try of teh day...
but when i was in sydney, i noticed where i parked the car.. it was downhill.. not slightly up hill.. so maybe that has somethin to do with it...
in sydney, on even freezing cold days, would start straight away
https://www.sau.com.au/forums/topic/2341-cold-starts/#findComment-43209
I dont know about skylines because I havent got the same problem with mine, but in my old GTi corolla I had problems with starting it codl or hot, I would have to pump the accelerator to get it to fire..
After I gave it a service and a *new set of plugs* it started beutifully..
Give it a go..pull your plugs and see what they look like, check the gap. If they're no good replace them and see what happens..
If it still doesnt work then u may as well give your car to me....:D
hope it helps..
Scott
https://www.sau.com.au/forums/topic/2341-cold-starts/#findComment-43317
The ignition barrel has two wires coming from it when you turn the key to the "start" position. One wire goes the starter motor, the other wire goes to pin 43 of your engine control unit.
When you turn the key to the start position, the ECU senses that you are attempting to start the engine by using the starter motor, not attempting to roll start the engine. Since using the starter motor demands a bit over 100 amps of current, your battery voltage falls quite dramatically. To compensate for this, the ECU makes the injector pulses much wider to get the fuel into the motor. It may not do this if you have your foot on the accelerator so it could even be the throttle position sensor faulty or misadjusted.
If you had an alarm installed when the problem started occuring, take it back to the butchers... oops I mean installers who fitted your alarm and have them correct it.
Cheers
https://www.sau.com.au/forums/topic/2341-cold-starts/#findComment-43577
  • 4 months later...
Originally posted by macka
you run 11;1 with the to4 Adam?
14psi im getting 13:1 bad news 4 me
Cant even remember saying that :P
13:1 full load is pretty lean
Most guys agree with anything under 12:1 safe
After i fit my fuel pump in it brought it back down to 10.2:1 and then tuned to 11.6:1 roughly
https://www.sau.com.au/forums/topic/2341-cold-starts/#findComment-115954
My 32 GTSt also starts badly when cold. Can usually get it to go first try now, but sometimes 2. Ive just got mine back from having 2 exhaust valves done so its got all new plugs in it, theres NO internal issues with the motor. Still starts badly
Ive been told this is a common thing with cars that have had remapped ECU's or aftermarket ones. Many have cold start features removed. Mine is a Blitz Access ECU.
After doing 2 exhaust valves in cylinder 6 and ingesting an electrode, my advice to anyone out there wanting to run 1 bar with a stock intercooler is, DONT.
Red17
https://www.sau.com.au/forums/topic/2341-cold-starts/#findComment-116193
Red17
You dont think that it would of still happened if u were running lower boost or a FMIC?
Well at least your back on the road..
I would hope tuners like Blitz wouldnt remove the cold start function on your ecu because its not to anyones advantage..but i guess its possible.
I have found when my timing is retarded slightly i have this problem, I assume its been checked but if you run abit more....18 degrees it may fix it..
just a thought
cheers
mac
https://www.sau.com.au/forums/topic/2341-cold-starts/#findComment-116344
Mine splutters every now and again on cold starts.
I tried turning the ignition to the on position for a couple of seconds and then starting but it did the same.
Slight splutter then up come the rev's.
Also on the note of AF's.
When i had mine on the dyno with the new fuel pump on 15psi she was down at around 10.5:1.
Is that normal for a 32 with a stock turbo?
https://www.sau.com.au/forums/topic/2341-cold-starts/#findComment-116352
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
