Make: nissan
Model: 1990 series 2 a31 cefiro
Milage: 200,000 i think from memory
Transmission: r32 gtst auto
Colour: just painted 2 weeks ago, mazda colour, think its called phantom blue
Complied? yep with 12 months rego
RWC supplied? yep 1.2 months left
Currently registered? yep
Price: eoi at this stage but the completly stock a31 rb20e's are 5-6g so 8G
Contact: pm or 0434961606
Comments / Modifications: just had it painted, new uras bodykit, new bonnet,
Images: below
basically im only selling because i want to save and get back into a fc rx7, so swaps for a very very cheap daily driver (charade/excel)
well its a pretty optioned cefiro with
* sunroof
* black and grey interior
* its a s2 so has the kouki tail lights, s2 front grill and projector headlights
* kyb struts ( handles quite well )
* has a very fresh re-spray only about a week old
* uras monkey warehouse body kit
* shaved rear spoiler
* it has a good strong rb20e and auto but its a simple an cheap job to chuck in a rb20det manual
* electric windows, sunroof, mirrors, seats ect
* sr20 silvia rims with 80% tread
its a really nice looking car with electric everything but i just cant resist the urge to get into another rx7
will consider either swaps for a really cheap daily 4 cyl with cash or a fc rx7
oh and i have recepts for about 4200 for the paint and panel
cheers
https://www.sau.com.au/forums/topic/234158-eoi-eoi-nissan-a31-cefiro/
on saturday a r32 gtst automatic gearbox was fitted and shifts really well also is alot stronger then the n/a box that was slipping, also had the auto serviced, a new aircon compressor was fitted and a new power window switch, spent quite abit in the last week, engine was also serviced at the same time
everything is sweet with the car and its looking sweet, perfect p plater car and awesome daily driver
note: plates dont come with the car either the gf would kill me
cheers
  • 4 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
