Item: HD cusion button Clutch
Age: 4 - 5 months
Condition: almost brand new
Price: 500
To Fit: (What car) R33
Contact: 0430 356 237
Comments: Virtually Brand new exceedy HD cusion button clutch, 1 dyno pass, then out she came, (motor Blew up)
Item: Garrett GT3540
Age: 4 - 5 months
Price: 1500
To Fit: (What car) whatever
Comments: Almost spanking GT3540 .63 rear housing, with oil and water lines made for a 25, went on the motor, did one dyno run, blew the motor, I am now well over it.
Item: Tial 44mm external wastegate
Age: 4 - 5 months
Price: 600
Comments: Almost spanking Tial 44mm external gate with screamer pipe, same story as above as to why.
Item: Dump pipe
Age: 4 - 5 months
Price: 150
To Fit: (What car) was on a 31, not sure what else it would fit
Comments: Highmount dump pipe, in heat wrap, flange for exhaust, and V band flange for turbo
Item: BOV
Age: 4 - 5 months
Price: 150
Comments: Turbosmart Type 2 Vee Port BOV, basically brand new,
Item: catch can
Age: ???
Condition: very good nick
Price: 100
To Fit: (What car) anything
Comments: G reddy catch can, was in the engine bay of my new car, wasn't even hooked up, think it was there for the "blng" factor
cheers guys
mark! (can send at buyers expense if needed!)
BOV sold,
sorry mate, dunno the part number I can check the clutch next time I'm over where it is. but it was fitted to the car with a S2 RB25 and a 33 box, so I guess it would be no probs
cheers
mark
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
