Item:HKS EVC 3
Condition: A1
Price:$300
To Fit: anything with a turbo
Contact:pm or sms 0413595838
Comments:For sale i have a HKS EVC 3 boost controller.
3 boost settings - off, low, high
SCB mode - this is scramble mode. it allows you to run a big amount of boost (you set boost level) for a short amount of time (you set the time)
Overboost - you can set the over boost so if it hits the amount of boost you have set the over boost at the controller turns off dropping the boost saving your engine!
supports internal and external waist gate
good for up to 2 bar (30psi) of boost
Asking $300
https://www.sau.com.au/forums/topic/234442-hks-evc-3/
    • I had issues with my car today after removing the rear bumper. The headlights aren't working when turning the stalk but high beams are working and the rear tail light where the reverse camera is wired up won't turn on when the stalk is activated, but the reverse camera, tail light indicator and brake light all seem to work. I checked the fuses they aren't blown. I think the reverse camera could have possibly gotten pinched but shouldn't be as there is a decent amount of room. I did use the lights and loom for the license plate from the new bumper but also tested the old one in case but made no difference. This isn't for a skyline also. Any ideas what it could be? It was working when I drove I'm pretty sure, then on my return home I noticed my headlights weren't working.
    • IMG_6023.mov   In motion 🤙
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
