that would probably be only there 850kg pressure plate
the one i would get is similar its a 5 puk nice thick ceramic pads too and a rating of 1220kg pressure plate and rated to about 350rwkw
its up to you but im not going to keep wasting my time i will ring Doug tomorrow get more prices and start the group buy it will run for 4 weeks so you will have 4 weeks to decide what you want
  • Replies 69
For the price you can get better.
As already mentioned in this thread.
A bloke I know also had his ceramic Extreme weld/stick to the flywheel. :P
He was told it was because he was driving it hard and then turning the car off soon after which was a load of crap.
He would launch it. Clutch would stick and he would be left decelerating either between first trying to grab second or second trying to grab third. Not to healthy for the gearbox/motor. :S
Not all the time but enough of the time to be concerned.
Grab a tried and proven genuine exedy. There's also been good reports with those NPC clutches.
I really don't like the Extreme for the cost of their clutches alone. :S
I want to get a fairly decent clutch that isn't too hard for driveability but that can still take a hammering at about 200-220kw.
Money aside, Is a twin plate a good idea for me (they're softer arn't they?) or reckon I can get away with a single?
Ok, if u think it's a good idea. But is it gonna be heavy as? Is my left leg gonna become twice the size of my right? Well I do push that accelerator pretty hard so I might be alright.
By the way sled, thanks for trying to sort out the hoodie sutuation. Ur a champ! If u need anything don't hesitate to ask!
if you had approx 100kw more I'd say go for a twin plate but at 220kw you're around the same power as Steve (Madaz) so go with his ceramic group buy thingy.
Pete even 100KW more than im making and its still good for its rated to 350RWkw man
it may take a week for your leg to get used to it i drove one in a mates GTR for an evening and was used to it in 10-15 mins but ive been driving a lot longer and are on my 2nd HD clutch granted it is only 850kg pressure plate
yeah ill try and do the leg work tomorrow
ill add the aforementioned clutch in post #2 ill ask for the next clutch up that's the $900+ one for the GTR and double check twin plate prices and rebuild prices and see minimum quantities
i am taking Jema to the Show tomorrow also so i have to be diligent with my time
mine was slipping bad and now cant even get a gear.... i might need one that can hold a bit more grunt tho than 300-350kw
go post in the GB thread i didnt bother getting a price for his 10' clutch but can if your interested the 10' one is this
>>HERE<<>>$1023<<
incase anyone cares the car is in at extreme now, for a little bit more than the group buy price i got a 6 puk extra heavy duty button, chromeoly flywheel and replacement of the spiggot bearings/bush blah blah for around that price, if you want extra info about who installn it or whatever then pm, be happy to help
yeah for there $690 Xtreme clutch i would rather one of NPC's i've had 2 Xtreme clutches and there not that extreme i know a lot of disappointed customers too a lot are happy a lot disappointed that is all i'm saying
i can vouch for the clutches that madaz arranged as im the bloke that fitted it into oz_pommy r 33 his car has 250 kw at the rear wheels and this clutch grips like a turd on a hairy arse . its very drivable a little heavier on the pedal than standed but great value for money and does the job .
if you want too blow for bucks on a "brand name " just for bragging rights go right ahead if ya want too save some bucks and have something that works great then have a word to madaz.
cheers mid life crisis
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
