I concour with danny, from what you've descirbed i don't rekon its a blown turbo...Easiest way to check that is to pull the dump pipe off (if ya can) and check...Im agreeing with nightcrawler/sled/danny in popped hose/afm dodgy etc etc.....Go and attack those hose clamps and you'll soon find out! Maybe like has been suggested as well an ECU reset and see if that helps?
  • Replies 44
Posted Images
had a huge look today top n bottom of engine and pulled on just about every hose i could find i cant see anything loose :3some: didnt fire it up though but when it was running after it happened sounded like turbo area.
it happened at night so couldnt see to clear but i could see the smoke out the back window prob not as much as that pic though.
perhaps a computer prob hmmmm could try reseting it or just send it to the workshop to get looked at.
car probably does deserve a dyno tune anyway
battery went flat n when i got it going again ecu didnt flash any lights, didnt see where the light that blinks is but im assuming it should be at the front.
after firing it up sounded ruff as and now wants to stall on me hmmmmmm's well time to take it to a workshop crap :)
GODZILA RETURNS
road n track set me back $160 well worth it, turned out to be crappy spark plugs n intercooler hose hanging off. dont know how i didnt see that but dont care now cause the initial "i think ur motor's f'd had me pretty scared"
car made 195kw at the rears again matching what i got at tillbrooks.
Edited by Inline 6
yeah i did check all the piping was bit hard to get to the intercooler piping undernearth but i did look at it. noize deff sounded like it was coming from turbo's though not intercooler. o wells its done now and im not much outa pocket
i got exhaust airfilters(some argue these lose ya hp) remapped ecu and run's at 12psi which i have now found out. pretty stock the way i like it :O
thumbs down to dial a tow who were 45 min late making me late for my first day at work.
Edited by Inline 6
10 is stock ive seen the long heated debates on it. 7 whateva's on the dial is equiv to 10psi was the final say on that topic :O
the dude was saying get some coil packs and we can add a couple more psi, but ill pass on cranking it up as i dont give a f about getting more power.
but ill prob still get the coil packs soon
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
