i got a problem with my r33 the engine shakes on idle and it hits da inside of the car which makes it very annoying this only happens when the car is warm i changed my coil packs to splitfire it went away a bit but the shaking is still there and this shaking problem sometimes causes my 33 on cold starts in the morning to shake even more like the rpm will not go up just stay at aroun 500rpm until i tap on da gas and then it will go up please some one help me with this problem as i want to install mods on the car but scared to coz of this problem cheers :)
https://www.sau.com.au/forums/topic/234909-engine-shaking/
could this do any damage to my engine if i do not loook into it strait away as funds are low atm
So you got funds to modifiy and upgrade the skyline,.. but not maintain it?
I think you need to get your priorities inline.
But i would look at the AFM next since coil and sparkies are new.
https://www.sau.com.au/forums/topic/234909-engine-shaking/#findComment-4117011
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
