Item:Hicas lock bars suit r32/s13, and bars to suit r33/34... 5 of each to get rid of!
Condition:Brand new!!
Price:$60 delivered or $50 pick up
Item: flywheel
Condition: just been re machined
Price: $100
To Fit: any rb engine 20/25/26
Item: oil cooler and relocation filter
Condition: nier new, all new o rings for addaptor plate
Price: $200
To Fit: universal.. any rb engine
Item: r32 stock wheels
Age: 15 years
Condition: average
Price:$200
To Fit: r32 gtst
Comments: each wheel has about 75% tread so well worth this price
Item: cusco strut brace
Age: unknown
Condition: excellent
Price: $100
To Fit: r32 gtr/gtst
Contact: pm or my number is 0409556340
Comments: pics available for all items..
Edited by lwboosted
https://www.sau.com.au/forums/topic/234975-parts-for-sale-r3233/
oil cooler sold.
strutt brace sold.
3 - r33 lock bars left!
2 - r32 lock bars left!
the tyres on the stock 6.5 wide 16 inch r32 gtst wheels are:
3 tyres are Bridgestone Potenza G3's one 75% the other 2 are only about 5% now
1 tyre BF Goodrich 75%
get in quick people stuff is going fast!!
Edited by lwboosted
1 - r32 lock bar left!
2 - r33 lock bars left!
wheels and flywheel still available!!
hey mate. depending if the last 32 lock bar will fit my 4 door GTS? Ill take it.
Pm me payment details and ill pay for it to be posted.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
