Doh! the Show will be finished by the time I get there..
Thanks for all your input guys..
Think I'll check out hq and the Casino and maybe a small bar or two.
I think I'm staying on the edge of the city somewhere, so pretty central.
I'm 30 yrs old but young at heart!! lol.
  • Replies 44
Posted Images
why dont you f**k off to melbourne then captain bringdown?
+1
sick of ppl payin out Adelaide.
I think melb is dirty to be honest. bottles etc all over the ground.
but lets not get into that.
Melbourne is far more boring! Adelaide has everything within easy reach.
+1
rundle street is the go
Belgium Beer Bar rocks! Most venues on Rundle St are good. :)
yeah nice place. awesome in summer. just wish they had more drink specials.
Rundle st has drunks like the rest of town on a sat night [including myself], but its more friendly.
ahaha...
Anyway, who cares about show, only thing from melbourne i wish we had here is noble park (yes im serious). Here people are afraid to drive their imports even just to and from work within speed limits... Street scene really could be better here... im pretty sure even alice can beat us in that.
being from Melbourne and all i prefer Adelaide, its laid back , good places to cruise , nothing is far away (good times driving an hour to see my best friend when i was in melb LOL)
hq is crap unless you have a commodore and some china chromes and a good cousin called habib,
dog & duck is meh
woolshed is alright
just go to the casino , its awesome as there , did photographic work there not too long ago and its really nice and laid back =)
if you get a chance , go up to mt lofty and windy point , pretty good look outs and you get the occasional hero "trying" to "drift" which is a good laugh
forget going to town, dog and duck has a stupid line up every saturday night, the only place i recommend is hq. Just take your car (of find a manual RWD/AWD hire car :D )and head up to lofty, through the gorge, thats the real adelaide that not many people see.
gorge rd is where my gf/ brother got killed on a bike a few yrs ago they reckon he was clipped by a car that didnt stop and help :-(
Edited by mid life crisis
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
