Item:Ipod Touch in black 16gb version.
Age: Brand new, box has been misplaced.
Condition: As above
Price: $400 ono
Contact:By PM if interested.
Got this as a gift same as my PS3 but i already have a Ipod, needs to go asap!
Cheers.
https://www.sau.com.au/forums/topic/235489-ipod-touch-16gb/
  • 1 month later...
  • 4 weeks later...
I will find out tomorrow 100%. Just waiting on some $$ to come through. Can you tell me, what network is it locked to and are you OK with posting at my expense to Melbourne???
https://www.sau.com.au/forums/topic/235489-ipod-touch-16gb/#findComment-4317806
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
