Yesterday went to Turbotune in Adelaide to fix a spluttering problem my car has had for a while. Thought it could be either a fuel pump problem or a coilpack. After an hour and some tests, ended up being a faulty coil pack. So happy to get that fixed coz it was driving me crazy. Then we dynoed it and I was shocked to see 201.2rwkw. Only mods are dump/front pipe, hks cat back, fmic, no boost controller but there was a boost increase to around 11.5psi. I was wondering if anybody made similar sort of power with or without boost controller. Will put picture of dyno when I get a chance to scan.
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/
  • Replies 54
to me that dyno is reading a wee bit too high
i had my car dynoed at Willall Racing and they use a mainline dyno
with a front mount, boost increase to 9psi, full zorst, splitfire coilpacks, pod....my car made 188.7 rwkw on a reasonably warm day
so from the mods that you are saying you have i would expect the same sort of power that my car has pulled out
plus no boost controller and ur hitting 11.5psi....umm have you had that reading out off a boost gague or from the stock gauge.
Edited by Krishy
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123368
damo had 2 dyno results from 2 different places.....
autosalon dyno if i remember correctly he made 161 something rwkw
and at southern hi tech dyno he made 184.2rwkw
that alone tells you that every dyno is different
Edited by Krishy
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123473
You WOULD have about 200rwkw if there was an aftermarket computer or your ecu has been remapped........
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123484
my 33 made 192kw with just a pod and turbo back three inch exhaust. i fitted the FMIC and it automatically pushed the boost up. final result is 205.4kw on 10psi :blink: ... i'm stoked:) oh and im running stock ECU and no boost controller
Edited by IZZMO 33
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123529
Southern Hi Tech: 182.4rwkw
Autosalon: 165rwkw
I got the lighter wheels back on and have a dyno day at graham west next month. im very interested to see what it pulls now, although i may have a few goodies on by then so the comparison wont be that accurate.
At autosalon in 4th it was hitting speed cut on the ctock ecu but hadn't maxed the revs yet, but at southern hi teech it reached max revs, so i guess each dyno is calibrated differently.
Edited by Damo_R34
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123552
same goes here, i achieved quite a boost increase after installing FMIC. Around 12psi. no aftermarket boost controller, and what appears to be the standard ECU. Same other mods that IZZMO mentioned - pod, turbo back exhaust.
She's running pretty nice.
Next thing i'll be adding is better coil packs - my oem ones are pretty fried.
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123577
Mainlines do read lower due to their more accurate correction factors but this is widely know, so you can compare DD figures to DD amd mainline to mainline but can't really compare them against eaach other.
I fitted the exhaust and cooler to this car, there was also some cat "modifications" so the boost increase is due to the increase in the exhaust flow.
The boost reading is off the MAP sensor on the exhaust.
I would say that the figure is pretty accutre due to how i only just pulled away in my lighter 180 which was running about 205kw(14.5psi) at the time when we had a run on the freeway on the way to Mallala (kept it under 110 of course).
As cubes and Jeff said prehaps it's just a freek.
Edited by D_Stirls
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123645
Where there is a boost jump it should only jump to around 9 or 10psi. Most 33's do that with those mods, but I think there are some that just might do crazy things and jump to 11 or 12 psi like mine and I dont know why, maybe just lucky. Plus turbo tune had just finished having they're dyno serviced on monday, so dont think the dyno is a problem.
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123646
auto salon was dead on actually. i had just got my car dyno tuned at boost worx a week prior and it made 2kws more than it had been tuned for.
anywho.. i dont find it hard to believe 200. i mean 11.5 is lot of boost for a rb25.
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123650
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
