Hey HOSTILE what else are you running in your car
In Mr r32 GTR I have a rebuild cat back Power Fc and im hooking it all up to a AVCR but i put my standard Air box on for Defect reasons and i want to keep it is there anything else i should do ? i know i have to get a Fuel Pressure reg because mines maxing out on the current tune but can my standard injectors etc handle your power once i get my N1's ? do i have to up grade dump pipes or anything not to sure what to do?
  • Replies 47
Posted Images
dumps pipes and front pipe will help alot if your getting bigger turbos, Helps with flow
thanks man ill try get some. do you think leave my standard cat? anything that makes it better i will do to it eventually but yea as long as theres nothing i need to upgrade should be fun to get them on and running
^^ Not necessary.... I have STOCK dump pipes, then a veilside exhaust system.
Yes it will flow better but for the power levels here they are not a must.
To answer the question above I am running STOCK internal RB26 motor with a few add ons... Power FC, HKS cams, 550cc injectors, Blitz SBC spec R, M's pods and of course the N1 turbos. My 326kw run was just starting to knock at around 21-22psi. I use 18psi daily which is around 300-310kw
I'm pretty sure a free flowing exhaust's main benefits is not the peak power increase, but rather the boost in midrange. Most people do exhaust first because it's a relatively cheap cost to power increase boost.
Front pipes aren't really important, cat back is very common, but I'd rather the whole lot :P
Most common upgrade sequence I've seen is:
Cat back exhaust, airfilter(pods or high flow panel), turbos/turbos + ecu depending on your turbo choices, ecu if not done yet, injectors, cams, dumps/fronts
Thats just the bolt ons...do internals when they go bang or any point between!
I reckon Ryan (ISC performance) was saying he would go to the 2860 - 10s if he was gonna do it again.... any comment ryan??
But yeah, seat of the pants test in shanes (puresx) GTR, those 2860s (-5s) hit pretty hard! :O
hey bud, Nah I'am definetly happy with the -7. Alot more responsive (same as stock turbo's) with a lot more kick (300rwkw-350rwkw)! I personally wouldn't upgrade to even -5 unless I was going to do cams etc to reduce lag, and then as soon as you start going 350rwkw + your putting alot of stress on an ald engine aswell. broken rb26dett = $$$$$$$$$. I was trying to convince shane to go the -10 as his 26 is completely rebuilt and he loves the kw! haha
Ryan
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
