Hi guys, been thinking of buying a PFC for my ER34 NEO with auto tranny. Recently I came across an article which says that the PFC is not ideal for auto tranny because of the computer logic being controlled by the computer or something along that line.
"PowerFC only supports manual cars (excluding Toyota). It will work on an automatic car however it will not handle gear changes and simply keep the throttle nailed during a gear change. This will result in jerky gear changes and stress placed on the gearbox. The factory ECU during a gear change will communicate with the auto box and drop timing, ignition to ensure a smooth change. For those wishing to use PowerFC with auto you should consider a mechanical auto gearbox instead of an electronic. The PowerFC should work fine with a mechanical gearbox such as power glide, transbreak etc.
This is because the mainstream ECU's in Nissan etc rely on the main cars' ECU for gear logic change control and functions. Cars such as the Toyota have a seperate ECU for the gearbox change logic and control so it's not affected. Apexi chose not to port the Automatic gearbox logic code (as its very long and complex) into the PowerFC because I suspect they found its simply not worth it & too complicated. You can buy an Automatic PowerFC for a Toyota Chaser for example and it has auto logic control under SETTING, you can set the shiftmap, ramp up speeds etc as it has the code to interact with the Toyota AUTO ECU that is seperate to the main ecu. So in summary - Auto PowerFC's exist & work but only for Toyota. We have seen quiet a few Auto R33 Skylines with manual PowerFCs - some report they work fine etc and there is no difference - do so at your own risk. " http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
Now, is there anyone out there with an auto tranny using pfc on the neo? and is there any trouble with gear changing or any other problems? As this article seems to be impressive and detailed thus i wish to get more feedback/advice from you guys before going with the decision to get the PFC.
I currently have a FMIC, 3in catback, BOV, airfilter, dump pipe and 108ks if that matters. And sorry for the long post. :)
https://www.sau.com.au/forums/topic/235784-pfc-for-neo-auto/
It can be done, a few of the stagea guys are running PFC's in their cars, (stageas are 97% auto's) but it usually done with a shift kit added to the trans. The only real issue is that the std ecu actually disrupts the engine ignition during gear changes to soften up the shifts so they don't have to be done under full hydraulic pressure (hence the comment about changes being made too harsh with the PFC) and the PFC has no way of emulating this, while it works, it will drastically reduce the life of your gearbox - just the ticket if you are planning on a manual conversion...
on neo engine cars, skyline or stagea, the auto computer is built into the standard ecu. so if you change the std ecu for a PFC the auto wont work, unless you fully manualise the auto. R33's i believe have a separate ecu to controll the auto, so they can get away with changing the std ecu for a PFC if they do abit of work to the auto ie: shiftkit.
hey dale. do you know if the auto ecu will do this still if a manual conversion has been done? (sorry to hijack thread)
Um,. AFAIK its not an issue if you have a manual conversion. There will be no signal from the trans telling it when to break ignition so I very much doubt it. The only KNOWN issue I am aware of, only concerns the R34 GTt PFC and you need to perform the "secret squirrel tweak" to stop the traction control output triggering the check engine light.
as explained here
http://www.skylinesaustralia.com/forums/in...t&p=3208663
been busy with my new job thats why i havent been logging in. hmm, so its true that its not advisable to have a pfc for auto tranny aye, and having would means getting ready to have a manual gearbox. hmm... ok, looks like i cant have it now cos my gf has an auto license and we would get another car after we buy a house next year... hope to read up more and hear more advice as well... :D
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
