Hi guys....been a while.....33 still going pretty strong...after nearly 3000 bux!....anyway...
I'm interested in this product......and what this advertiser is saying specifically about potential defects for uncovered pods.??
Two things.....
1) is this 'new law' true, and if so, when is it coming in?
2) Does this seem like good value?..Does it work?..I wouldn't be looking at the clear version so much as the plain black box version.
I understand the concept of seperating induction from heat sources as best as possible, but would this particular system actually help, or hinder?...My 'potential' set-up would be almost identical to the in-situ picture on that site.
Your comments would be very appreciated,
and thankyou for your time.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...A:IT&ih=002
Mate they all do the same thing.
Some people just find the flashing led neon crap ones are more interesting.
In melb I believe the rule is pod or FMIC .. not both.
FYI people do anything to sell a product..
hey mate
im in syd and i believe the law here is that pod filters are defectable. ive had a few blokes that have done my pink slip tell me that its a defect but they just tell me to say i put it on after. i am planning on getting the box for my 33 (the black one, not the wank wank clear with neon lol) and i believe it would protect from hot air getting through the system.
i think you would have to make up maybe some flexible piping to get the cold air from the front bar to the box. shouldnt be hard and at least this way you keep ur ass covered if the same rule applies for melb.
hope this helps
Plastic is better than metal as it doesnt radiate heat.
I once saw a ingenious idea to run PVC pipes from front bar, then to a pot plant .. air goes in hole and directly into the filter looked like another stock part cant get much better than that ghetto mod.
Personally I use a metal box with stock snorkel with a clear lid.. In sydney pod filters are illegal unless boxed. In general they are illegal for noise.
Jaye U have pm
Edited by DECIM8
I think most people toss up between plastic and metal pod sheilds all the time cos of the heat radiation side of things (after all we do want cold air), but the main point is that plastic can be just as bad as metal. Sure metal absorbs heat and doesnt disapate it as quick as plastic, but plastic really doesnt even prevent heat from going thru it. The most effective thing to do is go to clark rubber or summwhere and line the inside of your sheild\box with thin rubber or some sort of insulation. Looks crappy sometimes but i guarantee that pod air temps will be alot colder than the engine bay.
hey mate
im in syd and i believe the law here is that pod filters are defectable. ive had a few blokes that have done my pink slip tell me that its a defect and ive had to replace it with the stock box to pass. so ive just left the stock box on until i get that same box for my 33 (the black one, not the wank wank clear with neon lol) and i believe it would protect from hot air getting through the system.
hope this helps
sorry had a typo in the first post i did :thanks:
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
