I know i shouldnt be really starting this thread....but l8tly i have been seeing cops everywhere. i mean at least 8 a day. Im not being paranoid but especially after work, or during lunch time. Weekdays. Its ordinary to c a lot during weekends, but weekdays? I've even seen some undercover ones as well. like a wrx with rims and an exhaust!
looks like its revenue raising once again.
https://www.sau.com.au/forums/topic/23612-l8tly-cops-everywhere/
Guest INASNT
And the police minister want 1500 more of the pricks to join!!
I recon we go around with a few shot guns and blow all these new bs 4km/h over fixed speed cameras away!!
I have access to 4 hunting riffles which my uncle uses wit him gun club!!
I might even pay terrance a visit with 1 of those riffles :O
A quote from a friend of mine: [at least I think he is a friend :confused:]
"Just because you're paranoid doesnt mean they are not after you" :Paranoid:
J/K :O
yep..heaps....saw @ least 3 police cars today and @ least 2 unmarked.....I had a drive around Sunshine, Footscray, St. Alban, Deer Park, & Altona......heaps of coppers.... don't ask y I was driving around :rolleyes:
