there's actually an operation atm to crack down on stolen cars, they're trying to meet a target of a number of rego checks a day. Well das what my mate who's an undercova coppa told me.
Remember guys, its only the traffic cops we hate...
I spoke to a mate who's a cop and he said he was only ever in a bad mood when doing traffic shit. Not to mention he's beaten most of my speed records :D
Originally posted by Champinco
hey nismoid,
were u in tullamarine on wednesday? turning on to the freeway (towards city) from mickleham rd? at about 6ish? i think i saw u once again
nah. the car is @ the mrs ATM. i got no license lol!
so she is driving the beast to keep it running.
Plus her chev is getting air bags :D
but yes. ONLY the road/traffic coppers i have a problem with.
Other members like the ones that sort out domestics and all the other things are totally reasonable and level headed.
I got 'chased' down the road at 50km/h by a copper who also told me that my exhaust was too loud, and I needed a EPA test and had to hand in the result within the next 28 days!
I saved him the trouble and pulled out a piece of paper from the glove-box... an EPA test they did on my car with I got the exhaust fixed 15 mins earlier in Box Hill! :D
They just have bad days... get sh!tty 'cause they get traffic duty, and pick on ppl... not to worry!
:bahaha: what did he say to that one? :D
I think if you've previously had an EPA test its a good idea to carry the results around. Even if legally they hold no ground the second they are done, its a pretty dickhead copper that goes and puts you in again just after having being cleared. They can, but well there are grounds for complaint if they keep trying to dobb you in when its fairly clear you're not over the limit.
he asked me how long it took to do on my computer...
I politely asked him to come back to the garage with me if he thought it was a fake and to ask the person that did the test for me :)
I then basically through the results back in the drivers window and went back to his car, says not another word.
the good ol' "Have a nice day" must only be reserved for when they give you a ticket and know your day is going to be crap!
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
