Hey just wanting some advice... Starting to pull my r34 5 speed gearbox out & have the gearbox sitting just under an inch off the motor & cant seem to get it to budge any more. Can anyone tell me if the pull type clutch might be stopping it.. eg the clutch fork. Have removed slave & the rest and the gearbox free swivels and goes in and out. Any info would be great.
https://www.sau.com.au/forums/topic/236158-r34-5-speed-removal/
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
