hi guys
just got my first R32 gts25 with a RB25DE series one in it.
just wondering what the rev limit is for it and what people after mods have had them rev out to. as the tacho says 6500rpm but i thought it was 7500rpm.
i will be putting the 3L bottom end on it to by the way.
brentt
https://www.sau.com.au/forums/topic/236301-rev-limit/
2.5ltr's indicate the redline at 6,500 I believe and 2.0ltr have it at 7,000. Solid red on the tacho starts 500rpm past that. As for rev limiters, the last 2.5 I drove cut at about 6,800, definatly below 7k. Both my RB20DE's have no limit at all, rallycar will see 9,000rpm if I'm not careful.
Lot's of variance discussed here.
Raises the question, how accurate do you think the factory tacho is?
Edited by screamin'
https://www.sau.com.au/forums/topic/236301-rev-limit/#findComment-4138266
