Looking For A High Recomended Tuner/builder In Melbourne? Plz Help?
need a tuner in melbourne that is worth the money an does a awesome job no half assed tunes...for current set up an new engine build not to far away... rb26 has current set up of
arias 87mm forged pistons
eagle H beam conrods
acl race bearings
tomei metal head gasket
full engine balance
ross balancer
jun oil pump/colar
tomei sump baffle/oil restrictor
external oil feed back from head
tomei 260deg 9.15 lift pon cams/valve springs
full port an polished head
cam gears
hks 2530's
trust 125mm drag cooler/oil cooler
rb 25 afms
sard 700cc injectors
bosch 044 pump
apexi pfc
split dump pipes
twin 3'' into single 3.5 apexi n1 exhaust
hks evc4
the car still has stock turbo manifolds an turbo acuators an want to change them so will need a tune current set up made
347rwkw on 18 psi on a crd tune so i need a new tuner to deal with as sydney is to far away an i live 2 hours from melbourne also changing fuel rail an reg at same time an maybe some nos so hoping to get a bit more out of it for the drags so guys please help for a tuner an any more parts that may help that i should have????
Racepace hands down, plenty of threads about them.
Although you wont need half the aftermarket stuff you want to put on there :)
Plenty of cars making much more on factory manifolds, rails, regs and so on.
yeah cheers i have a fair few of the bolt on's already for the new engine in a while to come so i thought i
i might use them....an i brought the manifolds an hks actuators used off a mate an wanted too see if i could get a bit more out of my current set up
Try Dr Drift he is awesome does a good job.Ive seen some very potent
cars leave his workshop with happy customers.I drove all the way from
Syd to Melb to get him to tune my car and very happy with the result
and not only the tune the after sales support.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
