Yeah yeah...I have always wanted to experiment with doing your own DIY widebody kit. Like in Japan, they do it just using bit of fibreglass to create your own fenders. This way you can design it yourself, they just get someone to shape the fibreglass fenders, then they bolt them to the body of the car, and respray the car. I don't know how good it will look though, but might be worth a try on a cheaper car. Just in case it looks crap and you need to buy a whole new 1/4 panel.
https://www.sau.com.au/forums/topic/23641-red-s-front-grill/#findComment-526088
