Make: Nissan
Model: Skyline gtr
Milage: 97000
Transmission: manual
Colour: Gold
Complied? yes
RWC supplied? yes
Currently registered? yes
Price: Offers above 35 k will be accepted
Contact: 0403355696
Comments / Modifications
Posted an add a while ago and it gone lol Car just featured in ACDELCO magazine so look out for that
Forged engine
Cp pistons
Jun oil pump
N1 water pump
Oil drain added to the rear of the head back to the sump
Tomie oil feed restrictors
Tomie sump baffles
Hks adjustable cam gears
apexi cams
Acl Race bearing throughout
Arp Mains + head studs
Tomie head gasket
Hks timing belt
All new hoses and Gaskets ( and i mean i replaced the lot !!)
Also in the bay
Oil relocation kit + cooler ( hidden nicely)
After market Radiator,
After market cooler piping and radiator Hoses,
Nismo Airflow meters,
Kn panel filter in standard airbox , (with some slight modifactions haha)
New O2 sensors
Huge 600x300x120mm Intercooler,
Black Air guide to hide it,
Garret -5s capable
Gearbox was completely reconditioned by me
including Syncros 2/3/4/5
3/4 detent keys changed as they always die,
every seal changed,
also pulled down the transfer
every bearing replaced.
Running Power Fc with kick ass tune from race pace.
currently sits on 341 rwkw on 17psi , 400+ on 24psi but its to much to use on the street
other parts changed out .,
coil packs,
The altessa pump ,
Hicas lock bar added ( rear powersteering pump impeller taken out to completely disable it but still keeping the cooler )
Bilsteine coilovers all round.,
18inch wheels with new rubber.
D-speed clear indicators,
front + rear sway bars also one in the middle of the car,
Torque split controller added with a 2wd/4wd switch (in the console)
Boost controller hidden in fuse box with piping
Oil+boost gauge small and tucked away nicely
There is more but i cant rember it
Cost me 44gs and 700+hours
SERIOUS CALLERS ONLY ,
Edited by Gtrgodzilla67
https://www.sau.com.au/forums/topic/236647-r32-gtr-gold/
very clean car you have here mate,pretty sure you go to the same gym as me,
ive seen it parked there afew times and its a very genuine clean example of a r32
good luck with the sale!!
https://www.sau.com.au/forums/topic/236647-r32-gtr-gold/#findComment-4183248
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
