Item:HKS GT3037 Pro S turbo kit
Age:5months
Condition:used for about 5xxxkms with a max of 17psi, and only street use (no track/drag use) so basicially brand new
Price:not too sure yet, but will be selling it a bit cheaper than it cost me brand new as it is used (cost me just over $4000nzd new), at the moment i am looking to see who is interested ,so if you keen feel free to make me an offer
To Fit: r33 gts25t's and r34 gtt's, only for rb25det engine, but could be used on an rb20det with a few mods possibly
Contact:[email protected]
Comments:
Just making this thread to see if anyone would be interested in this as im 99% set on returning my car to stock and selling it (upgrading to a gtr), comes with everything you need to bolt it straight on to your rb25det, turbo, actuator,lines,gaskets,fittings,braided lines, vaccum lines, stainless dump pipe, silicon joiners, compressor elbow etc etc, this is a full bolt on kit and nothing needs to be modified to make it fit.
This made 270rwkw with 17psi on my completly stock rb25det using 95octane fuel, so has the potential to make over 300rwkw with 98 fuel and a little more boost.
I can arrange shipping to australia at the buyers cost, ofcourse.
Cheers
Jason
^^ +1
More Spec on the turbo please ;)
i.e internal, external, housing size... Is that a straight bolt on kit?
Internal wastegate, has hks adjustable actuator, has the 0.68 hks exhaust housing which can only be used with the hks split dump pipe that is made for this turbo/turbo kit, and yes like i said above it is a full bolt on kit, nothing needs to be modified at all, remove the stock turbo/lines and bolt this on.
Cheers
Edited by nizmo_freek
is this straight bolt on? so i wouldnt need to modify anything? do i need an ECU for example a power FC to get it tuned?
Yes ,as above this is a complete bolt on turbo kit for an r33 or r34 rb25det, simply unbolt you standard turbo/lines/dump pipe/intake etc etc and bolt all of the hks components on, no you do not need to modify anything at all.
An aftermarket ecu is not 100% essential to get this turbo running, you could drive around with it on the stock ecu (i would be getting the afr checked before going full throttle etc) but it wont go very well, you need to run an aftermarket ecu and get it tuned if you want to get the best on from this turbo (just like any other aftermarket turbo) , i suggest you do some research as to what you would need to reach your power goals with this turbo.
Cheers
Would want atleast $3500 for it, but like i said, im open to offers
Cheers
Hmmm, i cant seem to edit my posts, i meant $3500nzd
Cheers
Sorry to ask again but, When does full boost come in? @ how much RPM , does it lag or anything..
Here are my power and boost graphs from when it was getting tuned, it gets full boost (17.8psi at 3700rpm, and makes 170rwkw at the same rpm that it hits full boost) , it has a tiny bit more lag than the stock turbo, as you can see from the boost graph.
Cheers
hey interested in getting the kit, those pics above are of it before you put it on your car?, do you have any photos of the kit now?
thanks
Hey mate
Yea those photos were taking when i 1st got the kit when it was brand new, i dont have any photos of the kit now as it is still currently on my car.
Cheers :)
This kit will also come with installation instructions, and i will leave all the lines made up aswell (less headache for the next person who fits this kit, was a bit of a pain trying to follow just the pics in the instructions as all the text is in japanese) , i can also take pics of exactly how the lines are set up on my car now when i remove it , would make installation a bit easier.
If you want this kit i suggest you let me know, i already have a few people in n.z interested and have had p.ms from a few sau members.
Cheers :D
  • 3 weeks later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
