Heya guys iv got a s1 1993 Skyline gts-t with standard turbo but aftermarket boost control,, ITS AUTO lol ... When switching to power (changes gears every 3800rpm) the boost comes on every couple of seconds when iv got the foot flat to the floor "its rilly anoing'
what i need to know is it jus the auto trans or other prob ..
if you can help plz pzl help me its kind of hard to impress with a auto these days
https://www.sau.com.au/forums/topic/237017-boost-every-2-secons/
Not really helpful, but with my auto, even without power mode on, just in regular mode, the gear changes all happens in ~4,000rpm (except from 1st to 2nd which occurs ~3000rpm, when the car is ~25km/h) if you keep your foot down. But if you ease off the throttle at various point at certain speeds you can get it to change earlier on. But my car is stock all round. & my Power mode seems to push the gear changes to over 5000rpm, not really sure, since I never floored it in power mode.
ah ok,, well mines the same but i was just saying that it hapens one 3800 and there and a bout 4000 the jurking every 2 secons iv set the boost to about 5or 7 i will test in the morning if its just the ecu not allowing above 10psi
thanx for the reply
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
