i was servicing my car yesterday, test drove it after i serviced it, and it drove like a dream... now this morning it drove like dog's balls couldnt rev past ~2300 as it was spluttering but like something major... it was missing and felt like the engine was seizing when i tried to go past that. now i broke the yellow clip on the coil harness that sits in each coil pack. i only broke one of them, so i tried to do a quick fix, but im guessing its come loose. so im guess im driving on 5 cylinders?
the other thing is, i usually put BRKE6's not 7's. so could it be the cold 7's make it drive like crap?
and another thing is i changed the fuel pump to a bosch 040 on saturday. i put it in myself, could it be it i put it to high? it started to splutter abit after i did this, but i thought it was because for the 1st time in a while it was getting the right amount of fuel as i was wondering why my copper plugs that were in it lasted for so long as i had 15000ks on them and they still seemed to work fine untill i put the pump in. so i thought they were getting more then they could handle. i placed the pump so the bottom of it is inline with the bottom of the float.
my coils are tapped, and the plugs are gapped to .8mm.
any help appreciated. also i dont want to spend 100$ on a whole new coil loom, would much rather just buy the broken yellow clips.
thanks in advance, issa.
https://www.sau.com.au/forums/topic/237065-urgent-need-coilpack-clips/
I have a coil pack harness that's no longer needed from my R34GTT... if you can confirm that it fits, you can have it for $50 :blush:
im pretty sure the r34's run different coils/loom to the r33/r32's, can some one please confirm?
btw thanks alot for the offer mate, really appreciate it. ill let you know once someone can clarify it.
You could probably check with Nissan... I would check on the R32 we have but that has a RB25 in it.
im pretty sure the rb20/25 (non neo) have the same coil's so i would think the same loom as well. can someone please confirm this.
thanks.
ok, i just finished putting the coil loom in, AND ITS STILL DOING IT...
feels like its a spark plug problem, but it started happening after i put the fuel pump in. now my fuel pump (being a bosch 040) is really loud, and ive asked around and everyone has said thats normal. so i can hear it powering along and it doesnt really sound like its struggling. is it because i put brke7's or do i need to rewire the fuel pump?
mods i think we might have to move this one to the tech section.
cheers.
edit* does anyone know where the resistor is for the fuel pump, if its got one.
Edited by phat_man
where in syd are you ?
Auburn.
i think i may have mounted the fuel pump to high, and its got less then a 1/4 tank, so im going to try and mount it lower. as when i orignally mounted it, it wouldn't let me bolt it in, so i had to make it higher, but im going to try get it as low as i possibly could.
does anyone know how high off the bottom of the tank i should mount it. or how much clearence there should be between the bottom of the tank and the fuel pump.
thanks.
I would place all my money on faulty fuel pump installation. the pump needs to be mounted to the BOTTOM of the fuel tank and ensure the pickup is near the bottom and is not obstructed or getting blocked in anyway.
to be honest this is why for intank installs I always just go with nismo or tomei pumps as it can be a hassle trying to mount non-bolt in pumps properly inside the tank.
yea, thats what im thinking now.
but im still stuck as to how much clearence there has to be between the bottom of the tank and the fuel pump. should i make it so theres only 1mm, or 5mm?
also abit random but i would like to know, are the 'jecs' pumps the standard fuel pumps in r32's?
UPDATE!
just finished playing around with it somemore. lowerd the pump as low as i could get it while not touching the bottom of the tank. that seemed to work wonders. went for a good drive around my area afterwards, was going all well, felt 'healthier', then it started sounding like a rex... at that stage i thought either just the coil's or i need a new rb...
i know i wouldn't be able to stop thinking about it tomorrow unless i fixed it tonight, so i checked the coils and sure enough, one wasnt connecting properly, so fixed that one up, and then fixed another one up while i was there. had to cut and connect the wire together to save just braking them brown clips...
just got back from another drive, and it doesnt feel as 'healthy' as before, but at least now it doesnt sound like a boxer engine. could i have mounted the pump to low now? ive filled it up petrol so its got half a tank which should be plenty, as it didnt have as much before, i still want to be able to use the bottom 1/4 of my tank.
also who else is running copper plugs rated at cold 7's with 0.8 bar boost? im thinking of going back to 6's...
thanks for the help guys, appreciate it.
PROBLEM solved... well 90% sure it is...
just got back from 'testing' it, and all seemed good except for a lil vac leak somewhere or i think its the bov not closing properly(90% sure its that) it feels like its that anyway..... funny thing is its an apexi item might need some gun oil :ninja: .
just one last thing, the more you drive, does the pump get more voltage/amp's? as it seems to get louder after a hard drive then when i first start it. from what i know because its still standard wiring, this should be the case, can someone please clarify.
thanks, issa.
Edited by phat_man
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
