SAU Stickers for sale
8" wide
made of top grade vinyl
transfer film, not clear printed sticker
outside application
quality 3M™ Brand Vinyl Film
$7.50ea excluding postage
PM me orders !
feel free to ask any questions and ill get back to you !
Edited by DamageInc
https://www.sau.com.au/forums/topic/237129-sau-stickers/
  • Replies 160
PM me your bank account details and i will transfer the money over, or work out to maybe meet and exhange :P
no worries will pm shortly
ok it doesn't look as bad as i was thinking only problem is noone will see the URL unless there about to steal your car in the shopping centre :D
good job Mitch :banana:
yeah i just applied it in that position just so people could see it applied and see what it looks like :P
cheers mate
https://www.sau.com.au/forums/topic/237129-sau-stickers/#findComment-4148533
Definately looks good mate
well bring some out on the next cruise when that gets organised
if i am on the cruise or the meetspot then i will grab some mate
yeah no worries mate
maybe i should get one for the NX! :thumbsup:
If matty has them on his 4wd, and lukes got them on the ford, why not! :)
shoot me a pm if you'd like one and ill send you back my details :)
https://www.sau.com.au/forums/topic/237129-sau-stickers/#findComment-4149913
it looks really orange, not red. or is that just your camera flash? the red in the nismo or skylinesaustralia.com line seems much darker.
nah its red , just my camera was set to auto so doesnt show the colours up well ,
its a real nice red :rolleyes:
https://www.sau.com.au/forums/topic/237129-sau-stickers/#findComment-4150598
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
