  • Replies 42
its fairly underpowered for the mods it has, dynoed 289.9hp yesterday at hyperdrive, what bout urs?
haha no match for urs, 203hp@12psi, lol doin what i can being an apprentice and all, qualified 8th in b division tho and being only my 3rd tiem out on barbs so was happy with result
how'd u go?
nah car only makes 203, in all honesty i think im doing well in such a low powered car, smokes it up really good, i been focussing on pushing to car to its limits to remain competitive
hear's some funny facts for ya tho, in my last practise lap, i delaminates a tyre so badly, the strip, approx .50-.75m long flicked out and ripped off my fuel flap and half of my drivers side skirt haha i was impressed, battle damage ftw
hell yeh dude...i saw it later in the day fully pump smoke on exiting cat corner!!!!
bah, i did waaaay better in the practise laps earlier in the day they were the money makers, lol. my bro has been doing fotos for me etc and there are insane pics but yeh. speaking of later in the day, i got my first ever tow on cat corner during the first expression session, haha devo
http://au.youtube.com/watch?v=lHhM56a--qY
just found a vid already up on youtube, i actually appear in it yay, im in it for one clip at the 2:11 mark. if u look just before aswell theres at least one of the other boys on there too
harry, i got some pics of you and the others from around c-red cnr.....will hasnt posted any on flickr yet...(pussy!!!)
i'll post them up soon!!
ok cool sweet as send me the link, cheers for that too, are you reffering to my bro will too?
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
