  • 3 weeks later...
Hey Guys and Girls.
I'm new to the forum.. (As i pick up my new car today)
I'm from Brisbane and drive an R34 Gtst
Hope to see some of you out and about sometime..
I think you will find it's a GTT not GTS-T
Welcome.
https://www.sau.com.au/forums/topic/237683-83cks-saying-hi/#findComment-4223045
Hey bec. Very sexy 34! So what cruzes are you hitting up? i want to see this thing in action.
Keen on taking her to the drags? im trying to drag K along but she thinks its a boys event!
Dave
Hey Dave
Where were you sunday for the most wanted cruise Hey Hey hey???? lol
You better be coming on the skyline one.. :wub:
Tell her to get her butt out there.. hehe
We'll come out if your heading out sometime!!! ;)
https://www.sau.com.au/forums/topic/237683-83cks-saying-hi/#findComment-4253489
Got my Baby Tuned Last week From Dyno Tunz at Browns Plains!! Awesome guys!!
She gained an extra 10kw from the tune :xcited:
Still running standard boost tho..
Just have to get a Boost Controller so i can get a bit more out of her!!! :blink:
Mods are -
Sunroof
Full Nismo Body kit
Defi Gauges
Blitz Intercooler
APEXi RSM Metre
APEXi SAFC metre
Cucso Coilovers and Arms
GTR Wing
LED Tail Lights
Splitfire Coilpacks
Full Jasma 3" Stainless exhaust
Rear Floor Brace
Momo Steering Wheel
Ganador Mirrors
Changing the wheels and tyres soon..
Also putting some nice twin 3 1/2 inch pipe's on her..
Edited by 83CKS
https://www.sau.com.au/forums/topic/237683-83cks-saying-hi/#findComment-4254015
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
