My Skyline's sick, just not running well :D
At idle there's black smoke coming out of the exhaust (unburnt fuel) and if I boot it, still black smoke.
So running rich I'd say...
Now some sometimes when I pull up and she drops down to idle, it'll die off and come back up repeatedly. A bit like it would if an inter cooler pipe has come off (but there all OK).
This is not all of the time. All of the above is temperamental. One minute all seems well, normal. And the next minute not so good.
So, I'm thinking that I may be up for a new Airflow meter or O2 Sensor.
Something to note: It has been like this not long after a Service and Tune at 'Un-named firm' about 1 month ago.
Something else to note: I have installed a Air/Fuel mixture gauge, this involve wiring to the O2 Sensor. I installed this before my previous service and tune
where there was no problems. So I don't think this is the problem unless maybe, there's a voltage issue of some sort. Long term load/drag thingy... I dunno... :cool:
And here's what is really freaking me out. My Taco has freaky moments just as temperamental as the above and started the same time. It'll be fine doing its job, next
minute it'll be flickering all over the place. Then go back to normal :)
It's different from day to day. What has happened?
Anyone got any idea what may be going on inside my Skyline?
Or know of some things that could cause these problems?
I've got it booked in to be looked at next week. Have to get it sorted so I can stop worrying and enjoy her again.
Thanks ppl
https://www.sau.com.au/forums/topic/237742-sick-r33-gts-t/
where there was no problems. So I don't think this is the problem unless maybe, there's a voltage issue of some sort. Long term load/drag thingy... I dunno... ;)
Thanks ppl
Does the smoke have a smell to it?? (fuel/oil smell)
https://www.sau.com.au/forums/topic/237742-sick-r33-gts-t/#findComment-4159567
I had the exact same problem my issue ended up being the AFM
Yeah I'm leaning towards AFM. Because it's running rich on and off. I'm starting to think. If the AFM is starting to sense in-correctly it may have an affect on the Taco too
causing it to do it's flickering thing.
Big sniff... cough, cough, cough... Fuel :)
Have given the AFM a bit of a clean, has been running fine today. I wont know if that'll do it 'till it has a hissy again.
Been ringing around for prices today. AFM with (Pink) Sticker I've been quoted between $150 - $295. Bit of variation out there.
https://www.sau.com.au/forums/topic/237742-sick-r33-gts-t/#findComment-4159662
Have you also tried re soldering the afm?? its only a temp fix really but its a def worth a try.
This worked. The terminals were broken off. Well are now...
I ended up taking out the four screws for the plug and pulling that out, witch I think broke off the last connected terminal. There was little resistance to take it off.
This is how NOT to do it I think LOL
Not sure how you get in there to solder them back on?? Do ya cut or pry the side plate off?
I ended up bending the terminals over a little so when i reinstalled the plug panel bit, they pressed firmly against the pins. Bit dodgy but has got me outta trouble and she running nice. Gave the sensor a clean too. Everything seems back to normal and smooth running.
I'm keen to solder them back on though. So a quick 'how to' To get the side panel off the AFM would be cool.
Thank guys.
https://www.sau.com.au/forums/topic/237742-sick-r33-gts-t/#findComment-4160836
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
