After having some oil sitting from the lower cooler piping, and having cleaned that up, it starts coming from the top return piping, I'm pretty sure my stock turbo is on it's way out.
Just wondering where, and roughlyyy how much rebuilding the stock turbo will cost. And how long does it take someone to do it, just so I have an idea to workout transport etc.
I'm not after an aftermarket turbo or more power, since I'm saving for my new toy and this car is most likely being sold to my friends mum next year (seriously), I just want to know what's the better way to go about it stock turbo-wise. Upon saying that, I MAY look into the aftermarket turbo scenario if the rebuilding is going to cost over $1,000.
I'll probably only get it done mid-november when I'm back but I want to get the budget sorted. Any help? Cheers. ;)
Edited by Magic
https://www.sau.com.au/forums/topic/237774-rebuild-turbos/
you are definitely looking over the 1.2k mark for a rebuild. You can ask performanz, i think they redid my turbos last time. The labour is usually about half of it and the other half going towards rebuilding. 2nd hand at this point if your plans are to sell is my opinion. As rev210 said you can probably get a 2nd hand one and put it on yourself which will save you alot.
https://www.sau.com.au/forums/topic/237774-rebuild-turbos/#findComment-4159412
i looked into this jut recently as my turbo popped and went to heaven
its not worth rebuilding, it will cost over 1k and you can buy the same thing second hand for wayyyy cheaper
i have decided to go the upgrade as i want more power :D
but dont get it rebuilt or upgrade if you plan on selling soon as the turbo kit im getting is over $2500
turbos are not cheap ;)
https://www.sau.com.au/forums/topic/237774-rebuild-turbos/#findComment-4159427
Oh ok. thanks for the info guys. hehe yeah Karl, I just spent over $3,000 on the WedsSport wheels and new rubbers that are being shipped atm, although it's only going to be on it with me for about 5 months-ish.. well that's the plan. Then I might buy another set with bigger offset for the new beast. ;)
So yeh looks like 2nd hand stock turb is the go.. next question... how will I know if I'm being sold an r33 rb25 or r34 rb25 turbo? is the size any different/markings etc? Obviously I don't want to downgrade..
https://www.sau.com.au/forums/topic/237774-rebuild-turbos/#findComment-4159574
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
