Hey guys,
I just got my R34 serviced, replaced the coils, adjusted the idle a little bit and replaced the boost sensor.
Now i realised when i gave it a bit, boost did not go over .86 bar at all. Why is that? Normally it will go to around 1bar of boost!! frown.gif
I'm stressed and worried!
It would have to be the boost sensor right? Does it need a reset or something?
Thanks!
https://www.sau.com.au/forums/topic/237986-boost-problem-r34-gtr/
That seems to the be the stock boost level of an r34, wouldnt be too worried. and it gives you some security against boost spiking in 1st and 2nd gear.
Try it yourself, nail the throttle in 2nd and see what boost you reach on the mfd.
then nail in 3rd gear and see what the boost reaches
ps: dont forget to reset the mfd (middle joystick) everytime.
you have an EBC??? computer???
Hey guys,
Thanks!
I know what your experiencing, mine does this to on occasion. More often than not mine will run up to 1.07 on the mfd, then every now and then something happens and it runs a max of about 0.8 bar and feels very flat and lathargic. I have no idea why, and its an intermittant fault, generally when its warm and it has been driving in a spirited fashion. I can turn the car off and start it again and it goes away!!! cant work it out...I was hoping it was just a minor fault [glitch]with the factory ecu, so i figured once i had a pfc it would be problem solved!!!! That may or may not fix the problem though.......
Im very interested if somebody can solve this problem for us, if indeed we have the same problem....
Paulr33 please help mate!!!! cheers!!!
Edited by Duncan1
Hey duncan, remember i had the same prob as you? well mines all fixed now after i installed my new EBC. I got the HKS EVC version 6.
it hold boost nicely at 1.0bar in 3rd gear loads but in 2nd there is no stopping the boost spike to 1.10-1.20bar. Im contemplating buying the HKS actuators which are preset to 0.8-1.1bar and see if that helps.
Oh a little problem found was a loose vacumn line under the plenum chamber which was throwing off proper boost control so you might wanna get someone to check it out.
Took my tuner 2 hours to diagnose the prob; we thought it was the ebc faulty.
I will run over the hoses, but I am pretty sure they are fine.
Before I could drive the car and hit 1.02 Bar of boost no problem, but yesterday after i got it serviced it just stopped at .86 Bar. Bit dissapointing because you don't feel the power come on.
So you think you can turn the car off and it will go away? You will reach 1.0 bar of boost then? I will give that a go too, see if that works. Just annoying!
If someone gets a new ECU or boost controller, let me know if that helps.
Thanks again mate, will get it sorted soon, ebc sounds like a good idea. Bit scary when you see 1.2 bar register on the mfd!!! feels great though!!!!
Sorry for gatecrashing your thread Turbo Piston.....
Edited by Duncan1
I have same boost controller as Johnny. I run 1.2 bar every day on stock turbos. No dramas.
If I go on a mountain run where I will be on and off boost continuously for a long period, I just adjust it back to 1 bar.
Turbo Piston, I would suggest pitting an EBC in for sure
Alright, I'm going to check all hoses and reset the ECU first.
How do I reset the ECU? I'm assuming there is a reset button on it?
And another way to fix it would be to get a boost controller?
Before all this though guys, what was your R34 GTR displaying on the MFD? did it vary as well? Or normally sit on the 1.0 bar of boost?
Looks like everyone's reading is different. I finally took my car out for a drive since i wrote this post, been sick in bed. Assuming all the hoses were good, I gave it a go.
Soon as I turned it on, I realised the MFD was displaying the oil temp I had 4 days ago, which is a bit odd, normally it displays - - since there is no recording yet.
Anyway got to the servo, turned the car off, turned it back on and the oil was back to normal -- good. Think the car needed a reset, don't know!
First gear .96
Second 1.02
Third (not enough road) :)
Did that several times, pretty much identical recordings, so maybe after the service it just needed to be switched off or something. Unless when its hot outside and it has been driven hard, it automatically reduces the amount of boost. Because during the service of the car, it was a really hot day and the car had been on for while and a bit of hard driving was used too.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
