Ok this is the story my mate has a soarer and i got it goin the other nite since it hasnt been started for 6 mths, we jumped started it took it for a drive ran fine besides a winey power steer pump, so tonite i went to get it goin again and it started but kept cuttin out, like i had to hold the revs to keep it goin, so i assumed altenator not chargin, oh we put a new battery in it btw, so i drove it home keepn the revs up cause as soon as i let go off throttle she cuts out. so i drove it and as i got half way down my street it started runnin sluggish like not goin over 10km/h den it cut out and wouldnt start, so we pushed it the rest of the way i havnt looked at it but any ideas what it could be, could the altanator not chargin be a cause of it runnin like shit since the electrics not gettin powerd to full potential, i havnt cheked plugs or fuel filter yet as it was dark but is there any ideas as they would be appreciated. I no its not a skyline and im in the wrong forum so i thought i give it a go any ideas will be greatly appreciated.
https://www.sau.com.au/forums/topic/238180-soarer-v8-40-litre/
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
