Hi guys,
I just realise that my R33 is leaking water through a pipe on the passenger side, just beside the engine.
I have some pics to show below. The arrows indicating the pipe is the one that is leaking. I think it is water that is leaking out, dont think it's oil or coolant. Also my wiper spray (dont know if it is what u called it), the one where u pull the wiper tube and water sprays out? Stop spraying water and I have no idea where to fill the water. Can anyone enlighten me? Thanks!
https://www.sau.com.au/forums/topic/238261-leaking-on-r33-gtst/
Was your A/C running at the time of the observed water leak?
The washer reservoir should be in the front left (passenger) corner of the engine bay, the cap is right in front of the LH strut tower.
Yes I was on the aircon while driving, but only notice the leak after I stopped my car and switched the engine off. There is a big white box on the driver's side right behind the headlights, any idea what box is it? Plenty of water in it, dont know if it's the wiper water.
It was probably the water from the a/c (a/c removes moisture from the air and dumps it down the pipe you have indicated. if you get under the car, you should see it is open-ended.)
The container is probably the radiator overflow. The washer bottle might be partially hidden by the airbox.
So is it normal? Or do i need to replace the pipes? My air con blows only cold air at 18 degrees which is the lowest and at 19 degrees and above, it starts to blow HOT air. Could this be the cause of the water leakage? and according to the other thread, the problem was solved from a switch, but i have no idea where the switch is located. Can anyone post some pictures or something? Thanks alot mates!
water leak sounds normal. leave that
Hot/cold air - vent is behind the washer/wiper stalk - need to remove most of the dash facing to check it
washer bottles is a Large white bottle behiond the drivers headlight - hidden under the lip of teh guard next to that is the radiator over flow
if you still confused, post a bigger shot of your engine bay
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
