Item: Emanage Ultimate
Age: used for a few weeks
Condition: dam good
Price: 700 ono
To Fit: (What car) came outta a skyline but comes with universal harness so can fit any car i presume.
Contact: via pm
Comments: just selling has i need cash bad, was going to get fitted and tuned in my car, but i would rather cash at the moment.
also comes with ignition chip needed for r34's n maybe other.
looking for a quick sale
https://www.sau.com.au/forums/topic/239093-greddy-emanage-ultimate/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
