1. turbo t28 bb genuine nissan with dump pipe, no shaft play spins very freely $600
2. exhaust 3" turbo back, not loud until you get going (5zigen) $400
3. r32 gtst front seats $90 ea
4. r32 gtst rear seats $50
5. r32 doors (inc all elec+mirrors etc drivers has slight damage) $100ea
6. r32 GTR wing black $100
Item: listed..varies
Age: vaires from 15yrs to 2months
Condition: vaires
Price: listed..will consider trade/swap if reasonable (pref r32)
To Fit: (What car) r32 or whatever (turbo suits rb, ca18 and sr20 very well)
Contact: ash pm or 0439872212 or email [email protected]
Comments: please feel free to ask any questions and i will do my best to help, more then welcome to come see the gear for yourslef too..
https://www.sau.com.au/forums/topic/239157-r32-bitsturboexhaust/
hey there, i will consider selling the door trims seperate if the doors dont sell in the next week or so.. ill let you know.. and i would be willing to arrange a time to be at home for the item to be picked up if you would like to arrange frieght/post .. post code 4000 bris cbd
yeah i'm on the northside of brisbane, so i can come and pick them up
you'll still sell the doors pretty easily without door trims anyway, people always getting in prangs and shit
let me know via pm or 0413377833
hello to all.. sorry my net has been playing up so havent been able to reply as fast as i would have liked ... YES you can arrange freight to melb if you want however i think u will find it expensive .. my poste code is 4000 so arrange fright and u can take the door.. YEs i have manifold still and yes you can buy it .. $50 and its yours .. call me or arrange a time to come grab it .. as for trims i will sell them if the doors dont sell in the next week .. so i will let you know how that goes .. 0439872212 txt or call if u have any questions
in regards to the manifold it is a stainless steal low mount manifold purchased from rolin imports on the gold coast .. its a cheap chinese copy that didnt quiet fit rb20 so it was heated and bent to fit around the bolts on the head .. it has a small crack on a weld . conditions not great as for what i have just said but it was running on my car fine..... as for the trims i will let you know this week.. anything that doesnt sell im just taking to a wreckers .. thanks
manifold has been sold.. rest of the gear is still for sale .. im reluctant to seperate the trims from the doors as i believe it will make them harder to sell .. i am moving house in november so i need to get rid of these parts.. make an offer and you may just get it..
this turbo and exhaust were making 250hp at the wheels on 14psi so if you want an upgrade for RB20, SR20, or CA18 or any car/engine for that matter this is a pretty damn cheap way of doing it with quailty parts !!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
