Item: NISSAN VH45DE WITH IMPUL ECU
Age: 1994 (was told this year when i bought it) with roughly 50k on the clock
Condition: great
Price: 1500 pickup/ + delivery
To Fit: (What car) 300zx, skyline, silvia, patrol + more
Contact: feel free to pm me or reply to this thread
Comments:
vh45de v8 engine, all accessories inc rare impul ecu and loom
Displacment: 4.5L
Power: 206kW @ 6000rpm
Torque: 400Nm @ 4000rpm
BoreXStroke: 93x82.7mm should rev nicely
Main bearings: 6 bolt mains with one piece cradle
Crank: 90deg forged steel
Rods: Forged steel
CR: 10.2:1
Fuel: Sequential multipoint fuel injection
Throttle: 90mm with tuned length intake manifold
Valves: DOHC 4 valves per cylinder
Ignition: Direct ignition with coil on plug
Standard red line: 6900rpm
Weight: 231kg
i bought this engine a few months ago for 2k. i was planning to throw it into my 300zx but realised i dont have the time right now to do the project, so i sold the car and bought another one. i need the money to help with the saving for a house.
These motors are unreal. they used these engines in the indy cars but for the street they have a de-tuned bottom end. these engines are popular in the US (check out nico.com). they are capable of getting huge power from stock internals and are a high revving v8 engine. Standard internals can handle over 600hp and produce some great torque figures. these engines are also used in speed boats, usually with a twin turbo set up pushing out around 900+hp
Edited by ed300zx
https://www.sau.com.au/forums/topic/239322-nissan-vh45de-and-impul-ecu/
These fit suprisingly well in R33 engine bays. They have a front sump so no mucking around there (unlike on the Z's). There is also a group buy on adaptor plates to mate up the Z32 5 speed manual gearbox being run on www.aus300zx.com
BUMP.....anyone?.....
would be a great project......there are some superchagers out there that suit this engine very well...or you could always go for a tt set up like this s13 silvia owner
He's got front mount turbo's and a custom inlet manifold so the bonnet will shut.
The manifold done:
Cooler piping done:
Front mount turbo's
Here is a short video of the engine above started on the stand, sounds good and shoots flames 8)
http://s42.photobucket.com/albums/e302/can...06_12070013.flv
thats amazing!
These are rock solid engines.
cheers mate, these are very strong engines...its a miracle you dont see them more often in jap cars....even just in a v8 form
bump...guys i need this gone....anyone interested???
BUMP
the engine and parts are located in cooparoo....but am happy to ship at buyers expense.
  • 2 months later...
  • 2 years later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
