would be interesting to know how much thrust it really puts out. my mates brother in law has got a propper model aircraft jet engine, and he had it bolted to a big heavy wooden table (the kind that takes a few people to move), and he started to spool it up one day, got to about 15% throttle i think it was and it started moving the table.... with two big blokes at the front of it trying to stop it moving. theres some pretty serious shit out there in relatively small packages.... only question is how to mount a gearbox to the back of one lol
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4187103
You can find instructions on the net. The outlet of the compressor is fed to the exhaust inlet, mixed with fuel and ignited.
yeah have seen some instructions on the net seems easy to do....
outlet of compressor goes to a combustion chamber then to exhaust inlet. need to have a sprk plug in the combustion chamber
to ignite the LPG.
but need to know what sort of pressure is safe to run in the combustion chamber without blowing the turbo apart :(
and also what sort of oil pressure i would need to run for the turbo.. im thinking it would need a good oil cooler too.
i have read that you can get these things revving to about 130,000 prm :ermm:
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4190339
but need to know what sort of pressure is safe to run in the combustion chamber without blowing the turbo apart ;)
i have read that you can get these things revving to about 130,000 prm :)
pretty thick cast iron with a gaping hold in the back of it (where dump pipe normally goes/where thrust is generated) i rkn you could get heaps of pressure in there no worries.
and turbos spin well past 100,000rpm on your car anyway, what you've mentioned isnt anything crazy
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4190393
Well there are two main ways of doing it. You can connect a shaft directly to the rotating center of the jet turbine and feed it through a huge reduction gear or you can use the outbound trust to turn a "windmill" feeding a smaller reduction gear. The yachts I work on, some have jet turbines, they're great! little maintainance, produce masive amounts of HP in a very small package.... great for getting your 600gt 200+ft yacht to do 40+knots (and engine room fires!) and they run on straight diesel!
As for an automotive application, I would use it in conjunction with your piston engine. Use a "windmill" connected to a reduction grear, to an electromagnetic cluch arrangment, drive shaft, feeding a modified gearbox... hmm
Hell you could probably have a go at feeding the power to the front drive transfer case on a GTR gearbox... for a laugh!
Justin
Edited by XRATED
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4192370
im not familiar with jet engines and jet turbines, i know they use one in the y2k jetbike, and they use em in helicopters and tanks n shit, just didnt know they were the same sorta thing, how do they do it in choppers and tanks and stuff?
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4199856
I'm fairly shure the y2k was a direct shaft drive through a reduction gear (2 speeds- faster and stoopid fast) with some style of "buffer" or "slipper" clutch... Tanks are either multi geared (auto trans) direct drive, or hydraulic pumps and motors driven from the turbine and choppers are either direct drive or the turbine drives a generator that creates DC power to drive an electric motor coupled to the blades.
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4200992
so how fast do these bigger motors spin? like in the y2k or in choppers/tanks? what about the diesel ones in the yatchs?
18000-25000 rpm is the upper working range of the larger units I've worked with. Helicopters probably more... Y2K less.
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4203280
The hard thing is getting the flame holder right, you want it to burn all the fuel before the turbo but not blow out the flame when giving it some throttle.
Here's a good link for a really basic one - http://www.junkyardjet.com/primitive.html
And finally, a good use for a spare set of N1's ;)
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4204884
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
