Hey,
ok so ive finally gotten my car out of the garage, but then i decided to take the car up and down the road just to make sure its running sweet,
so i took it to the end of the road (probably didnt go over 30kp/h), then on the way back boosted it a tiny bit maybe only to about 4g then changed gear, it then dropped a cylinder which is what ive been having troubles with, then it drop a few more made a noise and then stalled, (the noise sounds like the piston slapping when it drops a cylinder),
So This is driving me crazy with it keep dropping cylinders and what not, what could it be?
I have changed the sparkplugs many times between iridiums and coppers,
I have installed a 500hp fuel pump
Split fire coil packs,
changed igniter,
changed resistor pack,
checked the injector (visual check) injector 6 was pissing out fuel from when i first install them but it looks fine now,
fuel pressure is fine, on idle i think it was 37psi,
i have a dr drift ecu and z32 afm, but i dont know why it would drop cylinders like it is, if i turn the car off and back on most the time all cylinders will be firing but then will soon stuff up again?
im pretty over this and thing of taking it to a workshop,
Cheers JV
https://www.sau.com.au/forums/topic/239869-need-help/
Sounds like a good suggestion.
Have you tried talking to Sam about it?
who's sam?
yeah its just i cant figure out the problem i dno why its doing this?
EDIT: o u mean dr drift, yeah the car wasnt running right to start with turned out ti was the alternaotr that went in it so it was trying to run of battery, thats all fine now, and its not the chip because it did the same with a stock computer and afm in there,
did a ecu test and it came back all ok
Edited by sly32
https://www.sau.com.au/forums/topic/239869-need-help/#findComment-4190128
Nah, I meant have you spoken to Sam about diagnosing it?
Or did you get his chip done through some other place like Mercury?
nar i havnt, i sent my ecu down to sam to chip, it has nothing to do with the ecu though as i installed a stock ecu and afm to see if it was the problem but it wasnt,
on another forums some1 has suggested that it could be the grounding from engine and battery? maybe thats why when the revs gets higher and so does the charge if the ground is shit then it screws up? possible? sounds like it might have something to do with it?
z32afm has been tested and is fine, alternator is fine, fuel pressure and fuel pump are fine, coils are fine, changed the injector harness and injectors, split fire coilpacks are fine, coilpack harness has been changed to a fresher 1, (did the same thing on the old harness though) changed igniter, and resistor pack, so maybe it is the grounding? cause if it was cas then it would come up on the ecu check? and normally when the cas goes then the car wont run at all,
https://www.sau.com.au/forums/topic/239869-need-help/#findComment-4190700
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
