Hey all,
Had the problems with the engine dying randomly and spasmodically and falling back to the safe mode. Especially (almost only) after it was hot. Noticed that the AFM#2 voltage was dropping to zero during this event so opened it up for a squiz (run a power FC - go into check sensors screen). There is a copper pressing soldered in place over the circuitry immediately under the AFM cover. This is a obviously a noise shield(re interference shield) over the circuit board (CB). This copper shield was warping (expanding and contracting with the heat) and MAKING CONTACT with a few soldered pins protruding on the top CB under the shield, shorting the CB!!!!! I also resoldered all accessible spots in case of a dry soldier (doubt this was the cause though) and clipped the protruding pins back. Fixed. No problems. Don’t forget to clean the silicon sealant out and replace with good quality high temp stuff.
Next time you think the AFM is 'burnt out' or 'stuffed' give it to me so I have some spares!
Cheers all,
Dave
old news mate..
if you had searched you would have found a few threads on AFM issues with this fix already tried and tested in them.
good that your car is going again though
Bugger, I couldn't find any solutions on the forum, just heaps of theories and complaints matching the running conditions I was eperiencing. Which thread was it in????
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
