well in Japan they have a differne type of gas than is used over here!! the aircon can be filled with normal gas no worries, just have to pay extra to dispose of the old gas!! But should have been swapped over during compliance!
retro fit is not part of complience.
R12 is not illegal to use.it is for sale.and can be used.WHY BOTHER.i havnt seen a can that needed it.if the pressurse were funny/high it mostlikly needed a newTX valves and replacments are R134A set.
to retro fit you replace the reciever dryer[filter] and the new ones are R134A compatible.service valves adaptors[not needed].
OIL[important] if you use other oils or drop in gasses these can effect hoses and orings and worse clean out the scum on the inside the pipes from the old gass and cheep oil.
if you use PAG type oil you dont.its a good idea to replace oring anyway as high pressure tend to melt them.
R12 is over $100 a kg [about the amount you need]
R134A is around $10-25 KG and good oil is up to $40.[need 150/200 ml.
WHY BOTHER with blend gas or hydrocarbon..
panel shops and electricians use all sorts of fad gasses.these still have R12 in them.SP43F is from memory flavour of the month.This is very good in houshold goods im told.
the problem is the oil.ROCK OIL is the common type and aunty ESTER. VERY GOOD IN FRIDGES.
if they were good in cars then the factory would use them.
speaking of regassing, ive got an R33.. takes R134A.. Got it regassed as it started to heat up at the start of last summer.. I use AC only every now and then (robs power) - thought today I would chuck it on AC as it was quite a nice day, and its barely cold :D
the idea of climate control is you leave it turned on.
when not in use it will leakout.compressor seals ect.
6 months.I would say you got a leaking bit,have a good look for oil stain on pipes and conections.oil on the front hub of compressor will indicate shaft seal.
its normal to get small leaks on the cold side of a/c.as they are cold/wet most of the time corrosion and cracks are comon.
ive replace evaporators TX valves and compressors on R33.
leaks on the high pressure sise are normally works today stuffed tommorrow.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
