Hello Guys,
My V35 only came with the one key. I had the dealer in which I purchased the car from order the key from Japan.
When it arrived, the dealer had problems trying to get the car to recognise the key. Apparently there was a list of instructions but they are in japanese.
Does anyone know how I can get the car to recognise this new key? Any help will be greatly appreciated.
https://www.sau.com.au/forums/topic/240439-key-recognition/
Hello Guys,
Good luck mate. i'm having the same problem. no one in aus can program the transponder! if you find a way, PLEASE LET ME KNOW!
https://www.sau.com.au/forums/topic/240439-key-recognition/#findComment-4199349
Please look at past topic on this, someone do have the solution to it. It has been discussed many times here already.
https://www.sau.com.au/forums/topic/240439-key-recognition/#findComment-4199596
there is a thread on this.
short version:
findthe BCM - copy all the numbers off it. send a email to nissan japan requesting the immobiliser codes. cut and program new key with consult.
https://www.sau.com.au/forums/topic/240439-key-recognition/#findComment-4199745
**Solution if your in Sydney**
I had the same problem with only having one key. I ordered a spare key and took it to Hornsby Nissan as I've been told they've been successful in programming these keys. They had it programmed within an hour :P
It set me back around $85 to get it programmed.
https://www.sau.com.au/forums/topic/240439-key-recognition/#findComment-4199770
Yeah it's strange, the guy from the dealer I ordered the key through said they couldn't do it. However while speaking to the guy from Hornsby Nissan, he told me they use the same tools as other Nissan Service centres so he couldn't understand why others can't do it...maybe they have the magic touch? lol
He told me they've had about 6 V35's come their way so these guys don't get scared when they hear 'import'.
https://www.sau.com.au/forums/topic/240439-key-recognition/#findComment-4200273
Most Nissan Dealers talk to each other direct via their own Nissan Forum... they can transfer knowledge to each other this way. If you have someone you know ask them to get in touch with Honrnsby Nissan, with using this process.
Surely they will help especially if it is just using the current equipment
https://www.sau.com.au/forums/topic/240439-key-recognition/#findComment-4201251
exactly.
if they have a consult 2 or 3 and the immobiliser code then they are happy. programming the key is the easy bit (on assumption of a scan tool or consult 2/3.) the codes are the hard bit from your end. without those you can key the remote entry in but not the NATS system.
https://www.sau.com.au/forums/topic/240439-key-recognition/#findComment-4204184
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
