i had 230 ish and that was wheelspin delux!
no point going > 250 ish without awd imho
good luck! let us know how it goes!
its partly throttle control, brand of tyre, and width of tyre
Cubes has 300 and can get enough traction
and now i have 255x17x40 mine doesn't brake traction nowhere near as much
  • Replies 143
haha nice work man, ill see ya at Willall on Monday aswell, My car's done now just waiting for monday...
280-300rwkw here i come
Cool mate what Turbz you running now? I will be dropping off car at 7.30 and should be back there by 12ish be good to see your beast there also good luck with it mate.
I must admit i might have to sus out my suspension, beacause its not liking grip in first even with 265 Hankook V8RS rubber and 200rwkw. Wheel spin is fun tho! :D
268rwkw I had no issues getting the power down once I dropped on a set of better tyres.
300rwkw is a little harder but it still hooks up well and is quicker up and rolling even when it is spinning/bucking around a little than when it was hooking up and making 268rwkw.
Low profiles = FTL if you want to get the power to hook up. You need preferably 16" with a bit of a side wall or at the very most 17" no more.
I ran around on a set of wide 18's and they were useless for straight line grip compared to the 16's.
Gt35r with a .63 rear, should see a good kick in the back about 4k...laggy i know but i've had a responsive turbo, now im wanna pull some good power and see what that brings.
Can i ask what size and what brand your using joel? I'm keen to put stockies back on it for a bit.
yeah, you got a point.
i had 19s with 245/35 s, not really a good choice in tyre/size.
i learnt my lesson in modding the 33, one of which, BUY JAP RIMS!:cheers:
oh, and thrttle control? whats that? :D
jks
yeah alot of people assume the bigger the tyre the more grip! but as cubes said it's not the case! i don't know if anyone agrees with me but the standard suspension seems to have the most grip off the line! has something to do with weight transfer i think
Edited by nos man
It's a catch 22 sometimes, Squat is good for weight transfer and dampens the initial bang of the driveline, but squat can also induce excessive camber which can leave less tyre off the road. Having softer, larger walled tyres means the tyre doesn't follow the course of the squat as much leaving more tyre on the road. Low pro's are fantastic for the hills for turn in but wack for straight line especially in a 2wd. (as said previously)
hence why we used to run 90/10 shocks on the front & Mickey Thompsons on the rear for drag racing back in the day
yep thats why i have gone to stock wheels but with good tyres, i used to 19's with 265's on the back and they just wouldnt give traction, i have red many of articles in magazines wihch were written by Martin Donnin stating standard suspension is the best for the drag strip, so thats why i have kept mine in so im hoping my new power will be more traction friendly
Very much looking forward to seeing your car back on the road when you get back dan.
mm good result!
gotta be happy with that!
fun times ahead!
Yeah thanks car feels excellent, very smooth linear power. Second gets a bit of a skip along when it comes on to boost. :D
Nice...
Now for some cams to pick up ~20-25rwkw on the same boost and then 2-3psi more boost and you should get damn close to cracking 300rwkw. :D
Cheers Cubes.
Nice and safe on the Standard bottom end at the moment. It's good to know theres still more left in it if need be down the track.
Impressive results on a mainline dyno there Lee, you should see 265-270 on a DD machine.
Im going back to the drawing board, Wastegate was WIDE open but still pumping close to 20+psi. So ive decided to Go external Gate modded onto my DMAX manifold so i can regulate boost alot better. I could just wack on a .82 rear with a larger internal gate but i want to retain as much response as i can get my hands on so i'm keeping the .63 with looked fairly responsive and going external gate.
Much appreciated to Martin and Mark for the help. Top Blokes.
EDIT: martin seemed to love my setup, i was a bit unsure about the size of the bastard. :D
Edited by Ryanrb25
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
