Make:Nissan
Model:R33 GTS-T Series 1 1994
Milage: 133XXXk
Transmission: Manual
Colour:White
Complied?Yes
RWC supplied? N/A
Currently registered? Jan 09
Price:$17,000 ONO
Contact: Beau 0421575884
Comments / Modifications:
Engine Mods;
250rwkws- Tuned by Hitman Performance.
Slide Max High flow
Spitfire coilpack
Full 3" exhaust
FMIC
Z32 AFM
Nismo 550cc Inj.
Apexi Power FC w/ Hand Controller
Bosch 040 Fuel Pump
Gizmo Boost Controller
Excedy 5 puk Cushion Button Clutch
Body;
Recent Exterior Respray
Vented Bonnet
Full Body Kit
18X8.5" Lenso rims (90% Ecsta Tyres)
Extra set of wheels; 17X8, 17X9 Volteck
Isc Coilovers
Nismo Smoked Blinkers
Interior;
Original Mats
Momo Jet Steering Wheel
Nismo CF Gearknob
Saber Boost and water gauges in Trust Pillar
Kenwood H/U
Boston Splits 6" front and back
12" JL Audio sub with Pioneer 4 Channel amp..
Images:
Pictures Of Dyno Sheet and Engine will be up soon.
https://www.sau.com.au/forums/topic/240612-fs-r33-gts-t-manual/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
