he was working in the parts department, didnt catch his name. yeah i think it is. think hes got an ss or something, mrs has an evo.
says hes on here somewhere!
Might have left, new DP in the place just before I started apparently shifted quite a few staff about, I need local Skyline friends :(
Spotted a very tidy gold 32 stopped at the on ramp to the freeway at Somersby this morning
Then on the way back spotted a black 33 parked between the exit ramp and the lights at Somersby in amongst a few other cars
Also saw a white 34 with black bonnet on P plates but can't remember where now, was near all the dealerships at gosford I think
lol nah it was only last week i went there for some bits for my focus
Spotted a silver 33 on the side of the road at Heatherbrae earlier today, any of you guys?
Don't really know any local SAU'ers but there are a few tidy examples getting around up here :wave:
I guess driving a 6.9M van doesn't really help when spotting someone as i look like a retard waving :laugh:
1332395223[/url]' post='6285258']
6.9 is that all
I drive a 12.5 table top with a lower deck as well, you would have it easy in a small van like that. ( or did you mean pan as in pan tech )
white r34 black bonnet have green p's?
gtr front?
Well i always park my car there monday - friday as i work at the dealership. But its a R33 so hmmmm :D
hey man im still there lol ive only been there 3-4 weeks lol come up n say gday man
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
