Im telling you - its your work.
They can point the finger at us all they want, at the end of the day if over 30,000 users can use this forum from whatever connection... then its certainly not a problem with us :rolleyes:
  • 6 months later...
DMAC_25
I am still having trouble getting on to SAU from the work PC. I get this log in page, which says menu disabled, I try to log in but just keeps saying menu disabled. The only thing that works on that page is the link to contact the forum admin, where I have had no response.
$5 says you are running from behind a squid proxy (whatever that means, i cbf'd looking it up)
I just know its a problem and they are blacklisted. So it won't change, you'll never be able to access.
Feel free to post up if i'm not correct, however odd's on i am :yes:
Well that is shit who's smart idea was that? Internet provider, work IT or SAU Host?
Fkn sucks need to check it during that day
Well the proxy thing is your work.
The blocking of it, is our host. I would imagine this to be for reasons of safety/security. So as with all things - this comes first.
    • Is this where I say "Hey man my airbox cost me horsepower in my Naturally Aspirated Engine"? (I know you need them for legality in NSW)
    • 1.5mm alloy folded up, it will need a tweek, as the angled bend only got to around 45° as that was the max that the break press would get with the other bends, and I needed a fair bit more, but and the alloy is easy to bend too my will by hand once I trim the lower section out I'll Dremel out and form the angle and mounting point on the lower section when time permits  As for the lid, I'm looking at going a "cap", instead of a flat lid to hide the fixtures a bit
    • I got sick of thinking about batteries so just kept buying chargers. I've got a ctek (racecar), a "noco" thing from supercheap (tow car with 2 batteries), and an old "SupaCharge" branded lead acid thing (farm ute/mower) and will need 1 more when the Silvia gets a battery again (if the 86 stays).  I always make sure the charger itself is in free space/away from car etc, just to be sure.
    • The "long nose" diffs in your type of car, that have the speed sensor on the snout, are a pain because the casing is different from all the other short nose diffs. This means that the pinion shaft inside them is longer, which can make it harder to do certain types of diff swaps. But, if all you are going to do it swap the diff centre, and keep the gears (that's the crownwheel and pinion gears) then you won't have any problems.
