Speweing I didn't order some TE37s a couple of months ago. They're now $600 more expensive a set.....
So, I need a set of high quality forged 18 x 9 or 9.5 rims for my R32 GTR. I already have some R34 GTR, so I guess you now know my taste
Who has got something for me? Surely someone has fallen on hard times and needs to offload some hot rims....? :P
Need to have good brake clearance too.
Andrew, my offer still stands.
https://www.sau.com.au/forums/topic/241133-18-inch-rims/
check the parts section, there is a set of brand new 18x10+20 GT-C's for sale, don't clear r33/34 gtr brembos but might just clear r32gtr :blink:
Yeah, thanks for that. I've got big brakes going on so don't want any dish. Offset needs to suit brake clearances.
https://www.sau.com.au/forums/topic/241133-18-inch-rims/#findComment-4210654
heh, I ordered my TE's just before the price hike..
I've got 4x BBS lm (sp?) rims, the ones with the gold in the middle, polished on the outside... Pretty sure 18x10 no idea about the offset. Got 275 tyres too with ~60-70% tread.
EDIT: identical to these:
http://www.skylinesaustralia.com/forums/18...html&hl=bbs
https://www.sau.com.au/forums/topic/241133-18-inch-rims/#findComment-4210659
I've got 4x BBS lms (sp?) rims, the ones with the gold in the middle, polished on the outside... Pretty sure 18x10 no idea about the offset. Got 275 tyres too with ~60-70% tread.
Pics? Location? Could be good.
https://www.sau.com.au/forums/topic/241133-18-inch-rims/#findComment-4210664
Can order you in new work emotion wheels, even with the low aussie dollar we will try to give you a good price!
Ryan-0413804117
Thank you Ryan, but I'm hanging out for forged jobbies.....
https://www.sau.com.au/forums/topic/241133-18-inch-rims/#findComment-4221948
AP CP5555 and 355. Got anything? Maybe, just for instants TE37s 18 x 9.5 + 22 (my dream wheel?)
Ah, i see.
Well there's a few guys i can think of off the top of my head that run that setup (and larger) in Vic.
Have you seen the thread RPMGTR has? He's got a set of TE's for sale
Im in the same boat as you, well almost;
-APRacing front and rear
-378mm front discs
-335mm rear discs
-Prefer forged but will take cast if needs be
-Want 18x9.5
-Happy with offset between +25 to +15
If i find anything that suits ill PM you, if you wouldnt mind doing the same that would be great :P
https://www.sau.com.au/forums/topic/241133-18-inch-rims/#findComment-4244768
Ah, i see.
-378mm front discs
-335mm rear discs
-Want 18x9.5
If i find anything that suits ill PM you, if you wouldnt mind doing the same that would be great :)
No worries. Contra is on. +15 on 9.5 won't work for me so I'm not sure how it will for you.
http://www.1010tires.com/WheelOffsetCalculator.asp
According to this going from std R32 GTR rims to 9.5 +22 you push the rim out 27mm.....+15 makes this 34mm which is too much without guard rolling and camber etc. Hence RPMs rims are not suitable. They are basically an R33 GTR offset. Let me know if you think different.
https://www.sau.com.au/forums/topic/241133-18-inch-rims/#findComment-4244979
I've got Pesos burning holes in my pockets. C'mon. We're all going to be queuing up at soup kitchens soon. Sell me your rims. Keep food on the table!
https://www.sau.com.au/forums/topic/241133-18-inch-rims/#findComment-4256991
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
