Make: 1993 Nissan Skyline GTS-T
Milage: 140 000
Transmission: Manual
Colour: Gunmetal Grey
Complied? YES
RWC supplied? yeh
Currently registered? Yes until 05/09
Price: $14000
Contact: Nick 0411 585 611 sms or call anytime.. or email [email protected]
Comments / Modifications:
? Hks 28/35 turbo
? Front mount intercooler
? Air intake
? Splitfire coil packs
? Hks cam gears
? Walbro fuel pump
? High pressure fuel regulator
? Vg30dett air flow metre
? Exhaust
? Apexi power fc
? 350z 18 inch wheels and new tires
? full alarm system
? turbo timer
? boost guage
? heavy duty organic ceramic clutch
? headunit, amp, sub
? tinted windows
? heaps more + spares
plus dyno chart showing 261rwkw
Images: 2541223.jpg
https://www.sau.com.au/forums/topic/241328-261rwkw-r33-s1-gtst/
Swap for Twin turbo cressida and money your way?
PM me if interested.
Hey Mate,
If i was to swap it would more than likely be to something a bit more functional.. Im thinking about buying a motocross bike so i would require maybe a ute or a van or a vehicle that can tow well and is smooth and easy to drive... my r33 is my daily driver and im a bit over the heavy clutch in stop start traffic on the gateway everyday, also looking to clear my debts (hence why im chasing some cash also)
Sorry about that mate..
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
