Originally posted by JET-33
yeh 12.6 i believe drifta ran
gtr-34, i rememebr seeing you on the heathcote trip....lettin ya son drive it stil (lucky mofo)
what was the smoke that blew out on the run just after the burnout comp?
lol...well it is my car (the son speakin), well my dad had the first two dragz at Calder on the night, one doing a 12.7 and 12.3 and then i had a go on the last one and did a 12.3 so not bad hey..and the smoke was that from the oil burning. the pipe came off. So we put that back on and it was all good.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
